Ive noticed this since putting my coupe back together. The Ackermann angles are all wrong???
When turning on full lock the outside front wheel turns too much causing it to scuff wide (or drag when reversing) making a noticable bang boom noise and causing the car to rock as the wheels fight and then slide and give in.
The car has been 4 wheel aligned and is perfect in a straight line. I dont understand how this can be adjusted or have changed other than the steering arms being incorrect on my KW's??
Or have 1 F**k*d it by lowering it too much cos i think it looks cool innit
The other think i can think of is that its always been this way (due to non conventional ackermann of our steering arms pointing forward)
and the solid bushes are just exaggerating it all, the old jelly bushes absorbed some of the noise of the wheels scuffing??
The spec is:
KW v2 galv coilovers lowered till there is a slight tyre tuck in the arch.
Spherical compbrake top mounts
Alu subframe mounts
Black poly wishbone bushes
ABY rack with Bambridge Delrin Trackrod bushes
ABY strut brace
BBS RK 17x8 ET35 with Goodyear eagle F1 225-45-17 tyres
and the solid bushes are just exaggerating it all, the old jelly bushes absorbed some of the noise of the wheels scuffing??The spec is:
Alu subframe mounts
ABY strut brace
