Been fiddling around with a 20v 90 quattro today, I'm doing a 5 bolt swap to use B5 17" avus wheels, however poped one the struts in this afternoon and found the front the wheel is about 8 mm from the front the arch where as the backs about 50mm for the arch, hard to tell the rear bumpers off, but certainly isn't central.
My idea is to move the bottom ball joint back about 15mm if I can by plating the steel arm and drilling holes offset 15mm back.The issue with doing this is that the rear caster will be zero or infact the other way, this shouldent matter as far as movements in due to the road but I'm thinking its lilly to cause alittle squating under acceleration if I do this, anyone any input?
