is it just a matter of taking of the two ends and two mounting brackets on the subframe? mine just needs a bit of a freshen up ie qiuck wire brushing and a hydrate 80/por 15 freshen up will nothing need re-aligning after? mines a white line one, would it be advisable to renew the 2 poly holding brackets on the subframe?
cheers
Just to add, any of the whiteline rarb's will be going like this after a short while, the quality of the paint is quite shocking. I've not seen one yet that has not suffered after being on a car for a few months
