rear arb removal
  • vonbeck
    • 2455
    rear arb removal
    is it just a matter of taking of the two ends and two mounting brackets on the subframe? mine just needs a bit of a freshen up ie qiuck wire brushing and a hydrate 80/por 15 freshen up will nothing need re-aligning after? mines a white line one, would it be advisable to renew the 2 poly holding brackets on the subframe?
    cheers
    ABY Cricket Green Pearl Coupe, blk leather
    THE ONLY TROUBLE WITH DOING NOTHING IS KNOWING WHEN YOUR FINISHED!!!
    You need to disconnect the drop links either at the ARB or strut end.
    If you have a whiteline those polys cant be renewed as they aren't for sale as a seperate item, well this was when they 1st came out anyway.
    You dont need to renew them you just need to regrease them
    • Acidburn
      • 13459
      Agree with jamo
      Just to add, any of the whiteline rarb's will be going like this after a short while, the quality of the paint is quite shocking. I've not seen one yet that has not suffered after being on a car for a few months
      • vonbeck
        • 2455
        ok cheers will use water proof grease it should last a bit longer as for paint finish i agree mine looks worse than the original subframe
