Top Mounts
  • R5T
    • Jul 2012
    • 250
    Top Mounts
    Hi chaps
    Laugh if you want, but ... im replacing the top suspension mounts at the weekend. I was hoping that it would be self explainatry but my old man says otherwise and cant remember ... soo which way up ??
    Thanks guys
    Sam
    93' Audi 80 2.6 Quattro
    93' Audi Coupe 2.6E Auto
    90' Audi Coupe 2.3e 10v
    95' VW Polo 1.0 ...
  • PeterS
    • 423
    green is on the bottom, closest to the spring.
    Peter S
    1990 ErsatzS2 - track toy
    1991 Coupe Quattro
    1991 Coupe Quattro
    1995 S6 Sedan
    1995 S6 Wagon
    • Monkeymagic
      • Mar 2012
      • 3419
      it Will be very obvious when you get to it mate. the bearing sits on the top spring plate and the castle nut sits in the recess at the top.
      • R5T
        • Jul 2012
        • 250
        Cheers lads, just wanted to be certain
        Sam
        95' VW Polo 1.0 ...
        • R5T
          • Jul 2012
          • 250
          Evening guys, just another newbie question ... Will we need spring compressors/clamps to remove the top mounts ? Does the split nut on top hold the spring tention ? or is it just a case of taking the strut out and popping the mount off ?
          Sorry for the newbieness
          Sam
          95' VW Polo 1.0 ...
          • stocious
            • Jul 2012
            • 838
            Deleted
            1991 S2 3B Coupe, KW v1, solid sub frames, poly bushed, chipped, about 260 ish
            • driftin jo
              • Sep 2007
              • 2222
              Originally posted by stocious
              Mount can be removed/replaced with spring untouched!
              no it can't !
              • driftin jo
                • Sep 2007
                • 2222
                You need spring compressors, unless you want a face full of mount and spring
                • Monkeymagic
                  • Mar 2012
                  • 3419
                  or i big dent in your car!
                  • mcandmar
                    • Apr 2004
                    • 5118
                    spring compressors are a must for standard springs, H&R's you dont as your body weight is enough to compress them.
                    91CQ20v - Gone to a new home
                    93UR-S4 - The Magic Carpet
                    94S2Bus - The Emerald Express
                    • R5T
                      • Jul 2012
                      • 250
                      Okie dokie lads, thanks for the heads up ... we havent a spring compressor ... but we do have a workshop full of diggers and straps .. we will get around it one way or another ... me old man says he done his and doesn't remember using a compressor. Ill let you know how we get on
                      Sam
                      95' VW Polo 1.0 ...
                      • Monkeymagic
                        • Mar 2012
                        • 3419
                        i did my brothers standard coupe on the weekend. i guess you could get away without them as they weren't under much pressure. however its extremely dangerous in my opinion i watched some half wit dismantling some cheap coil overs guess wh
                        at the end result was. stitches in an eyebrow. you may struggle to push the cap down enough to start the castle out off.
                        my advice go to gsf buy the castle nut tools and spring compressor be about 30 quid and Will save the frustration.
                        • Pirvu Eugen
                          • Apr 2007
                          • 1978
                          • Country: Romania
                          Sam
                          this means you never saw an flying spring throw left hand wing and 2cm from your head. It was another car though.
                          • andy10v
                            • 5996
                            Mike did a good how to with picutres etc
                            With some lowering springs you can replace without spring compressors, and yes you can tie the springs down with the car weight on and then jack it up, I would not advise it though,
                            Sold ABY-stock
                            • R5T
                              • Jul 2012
                              • 250
                              Cheers for the help guys
                              All done thismorning, didnt have any compressors to begin with so we tried tyng a shackle and strap through it in a vice and pulling it with a 1 ton mini digger... the vice just kepy turning so we went on the scrounge around the industrial unit ... found a set of compressors from a cement truck company of all places soo got there in the end
                              However we didnt need compressors to ge the mounts off ... they just fell off .. and left the bearing underneathe the castle nut ..
                              In the process of all this whilst changing a side light i managed to drop my offside headlamp and shattered the lense into 7-8 pieces so if anyone has one please let me know I have a spare but it was the original i took off as it had a small crack in it.
                              On another note i tested the temp sender once when the car was cold, and again when it was at running temperature(after turning it off) ... dont really know what any of the resistance values mean soo any heads up would be appreciated.. Ill post them up in my main "Coupe Thread".
                              Thanks again guys
                              Sam
                              95' VW Polo 1.0 ...
