Wishbone on powerflex movement (video)
    #31
    Originally posted by Tonks4x4
    I have had the same thing using these bushes after just 100 miles.
    I fitted genuine Audi standard bushes 5 years ago and they are still as good as the day I fitted them and they never squeak either
    Tonks4x4 - The Land Rover Specialist
    No direct help I know, but I agree with Tonks.
    Have oem rubber on my cast ones.
    • mcandmar
      • Apr 2004
      • 5118
      Originally posted by Error404
      Something is not right there for sure. My guess is the wishbone is bent from removing the old bushes, BTDT.
      In my experience Powerflex are tricky to install as the fitment is very, very tight and once fitted there is zero movement by hand, except around the bolt axis. So either there is a manufacturing defect (unlikely I think as PU is cast) or you have a problem with the wishbone.
      It also looks lke you are missing at least one washer between the bush and the subframe as not only does the wishbone slide on the bush, but the bush slides on the sleeve, indicating there is a washer missing. HTH
      I agree, you have to beat them into the subframe with a mallet the fit is so tight. It looks like he does have the white washer either side of the bushing but its hard to tell for sure. Infact the bushings look fine to me, i think the problem is the a-arms.
      91CQ20v - Gone to a new home
      93UR-S4 - The Magic Carpet
      94S2Bus - The Emerald Express
      • BorisShakhov
        • Feb 2009
        • 224
        • Country: Russian Federation
        #33
        Does anybody know a factory dimension between centers of the arm ends?
        I'll try to measure them...
        • irishs2
          • Apr 2009
          • 2455
          I had 4 pressed steel ones here.
          I measured with bushes removed. So its internal dimensions from the outer of the arms were:
          1s pair was < 293mm >
          2nd Pair was < 292mm >
          Eric
          95 S2 Avant under rebuild.
          • BorisShakhov
            • Feb 2009
            • 224
            #35
            Many thanks, mate!
            • Jarno
              • Jul 2010
              • 41
              I have same problem whit my powerflex bushes. I have steel arms and powerflex bushes are correct ones.
              • stocious
                • Jul 2012
                • 838
                I just test fitted an arm and it doesn't seem like I'll have the same issue! Hopefully !
                There a very tight fit, so tight the washers might be tricky to fit!
                But I guess that's a good thing ?
                1991 S2 3B Coupe, KW v1, solid sub frames, poly bushed, chipped, about 260 ish
                • LHD_Kid
                  • May 2006
                  • 3695
                  #38
                  I fitted mine into cast fronts and pressed rears now 4 yrs ago (no squeaking since either)
                  No such issue, no movement at all and with the washers a very tight fit into the mounts on the subframe.
                  I agree with others, there are issues with either wrong bushes or something wrong with the wishbones....
                  • irishs2
                    • Apr 2009
                    • 2455
                    Yep, they are difficult to get in with the nylon washers
                    Eric
                    • stocious
                      • Jul 2012
                      • 838
                      I believe I'll be fine in this case cheers for the replys ^.
                      I wonder if the original posters arms had some distortion from a o/e bush change previously ?
                      Pressed in without support between the eyes kinda thing!
                      Curious as to the outcome of this! Seems more wrong the more I look
                      • BorisShakhov
                        • Feb 2009
                        • 224
                        #41
                        Mine are 282mm between inner sides of the bush holes. I'll try to replace all 6 arms with new ones.
                        Thanks for the help, mates!
                        • irishs2
                          • Apr 2009
                          • 2455
                          Good news !!
                          Eric
                          • BorisShakhov
                            • Feb 2009
                            • 224
                            #43
                            Good news !!
                            Do you have dimensions for the rears?
                            • irishs2
                              • Apr 2009
                              • 2455
                              The avant rears are not "parallel" so I picked a spot in above pic to measure.
                              Without bushes its 356mm / 357mm
                              Hope that helps.
                              Eric
                              • Skull
                                • 3506
                                • Country: Slovenia
                                #45
                                this is how they should be installed, + the white rings, you can see them here...
                                Audi Quattro WR
