Hi all.
My RS2 has been doing great since we found my disconnected vacuum hose to the MAP.
I have learnt the car properly through different roads and have mastered it in the rain- bags of fun
Only glitch I have is an intermittent beep from the dash which I suspect has something to do with the powersteering reservoir: whenever the car is parked for a few days ( its only driven on a saturday) I have a small puddle of fluid on the garage floor.
After replacing clamps everything was well for a while ( I had beeping initially due to LOW fluid level).
I now routinely check oil, coolant, powersteering fluid and brake fluid levels EVERY time before I fire her up.
So my reservoir is full, but I seem to think its OVERFULL if thats possible- it beeps despite there being fluid far higher than the upper line on the tank.
I dont see a MIN or MAX so Im a bit unclear on the correct level.
I know that the dipstick on the lid gives an indication, but It too doesnt have markings.
Possible faulty sensor as the fluid did leak into it at one stage- what should I use to clean the sensor?
Sorry for the long post and thanks in advance.
