Shock tower braces
  • NoNonsense
    Forum Sponsor
    • Apr 2004
    • 673
    Shock tower braces
    Does anybody know of any shock tower braces for the rear of a slipper wagon or saloon? I've been working on a triangular brace for the rear, but I'm running low on ideas here and looking for some inspiration. Cheers.
    Joe "NoNonsense"
    axis motorsport
    joe@axismotorsport.com
  • Lee
    • 1512
    Not yet. I will need something there when I get some bucket seats for my Avant. Was going to bolt a tube to the inner wheel arches and triangulate to the floor in several locations. It will be install once and not easily removable.
    Designun Limited....
    • 4WheelDrifter
      • Oct 2004
      • 5773
      • Country: Devon
      LOL. Sounds like it's going to sprout into a full weld in cage!
      SS
      • audiman
        • 4827
        A cage should do the job. No point in messing around!! Although insurance companies in the UK dont like roll cages, charge you loads for that.
        Tom C - www.rcmr.co.uk
        Audi UR Quattro
        Audi 100 C3 2.0 5 cyl 115ps
        Audi B5 RS4 645ps 911nm
        • 4WheelDrifter
          • Oct 2004
          • 5773
          • Country: Devon
          It's a bit hard to hide the fact that you've got a roll cage too!
          SS
          • NoNonsense
            Forum Sponsor
            • Apr 2004
            • 673
            Yes, as much as I'd love a full roll cage to tighten up the chassis, my car is a daily driver, and a weekend road racer and autocrosser. It's a four door, too. If I had a coupe, that would be a different story all-together!
            @ Lee: That's what I've been working on...it would be a triangulated bar, but adjustable to really pull in those tops to get more neg camber. I have a similar set-up up front:
            I can twist the strut bar to pull the towers in. Don't mind the rusty over-flow tank and battery tray...that was shorty after I got the car. I'll have to post pics of my engine bay now to redeem myself...one can eat lunch out of my engine bay now!
            The bar that I am designing now will bolt in with three (maybe five bolts). Basically, two on each tower will hold a special tang and be permanent. Then on the floor will be another plate with a mounting spot bolted in. To remove the bar, you'd only have to undo one bolt on the floor and untwist the bar. It's still in development, but I'm running out of steam on this project.
            Joe "NoNonsense"
            axis motorsport
            • NoNonsense
              Forum Sponsor
              • Apr 2004
              • 673
              ps...one of my friends who is a local road racer with me says that I should do an x-brace...he said that it would be much bettery than my triangular bar idea. I don't know what to think....a triangle is the strongest figure (think pyramids), but with an x-brace, the two bars would cross each other, but not actually connect. Plus, if the force is applied directly between the towers (ie...long side of a triangular brace), then you'd have more tentile strength and also more adjustability.
              OH well...I'll keep you guys posted...I will definitely have one by February, or else....
              Joe "NoNonsense"
              axis motorsport
