groove for security the wheel bearing
  • Tom_
    • Oct 2007
    • 1301
    • Country: Czech Republic
    Guys,i have problem, that groove for security the wheel bearing,its not there.Maybe there was,but after years and rust, its only some rests of groove.Any ideas?How solve this problem?
    Audi Coupe Quattro 2.3 20V
  • irishs2
    • Apr 2009
    • 2455
    The later cars didnt use the circlip. So there was never a groove.
    A better pic without bearing
    Eric
    95 S2 Avant under rebuild.
    • Tom_
      • Oct 2007
      • 1301
      so only press into the housing and than use a bolt to the shafts?Thanks
      • irishs2
        • Apr 2009
        • 2455
        Yes exactly, but as usual be careful pushing the hub into the bearing, support the inner part of the bearing from the other side, I destroyed one bearing this way
        You probably know that already, but no harm mentioning it.
        Eric
          Yes, press in only. Mine were like this. Takes a few tons to press in, so it's fairly secure
          • Tom_
            • Oct 2007
            • 1301
            Thank you guys,i´ve alread a panic,that i have again something "special"
              When you press the new bearing in make sure you only apply force to the outer race of the bearing
                C4 UrS Front Wheel Bearing info
                Not sure if this applies to the S2s (or 2.3L CQs) but with the C4 UrS4/S6s, you have to be sure to get the correct wheel bearing. The incorrect C4 UrS wheel bearing has two inner parts, split 18 mm/18 mm with a 1 mm gap and the same inside diameter (45 mm IIRC). The correct C4 UrS wheel bearing has a split as well but it is 23 mm at 43 mm diameter and 13 mm at 45 mm diameter (with a 1 mm gap) (see photo)
                C4 UrS Wheel Bearing PN Sleuthing results
                Example wheel bearing kit parts break down:
                  Yes the S2/CQ20v front bearing is also stepped, in fact I am sure it is exactly the same
                    Okay, good to know.
                    So the stupid question of the day (not for you Error) *IS*:
                    Which way does the step go? Larger step diameter in or larger step diameter out?
                    (I know the answer - I just want people to think this through).
                    • irishs2
                      • Apr 2009
                      • 2455
                      Homework
                      Eric
                      • Nuvo
                        • Nov 2003
                        • 3825
                        Larger diameter faces out. Paul N. wrote a nice guide here.
                          Correct. Otherwise, you can't get the hub pressed in properly without breaking the bearing.
                          • RoadKill
                            • Dec 2004
                            • 567
                            i used the old bearing to push the new one in on mine
                            service tec @ East Kent Audi
                            S2 ABY
                            B8.5 A4
                            • Tom_
                              • Oct 2007
                              • 1301
                              Thanks guys.....
