C4Q Rear Control arms
  • philj
    • Feb 2010
    • 377
    Where is the best place to get these? GSF don't do them, ECP only have q drive, VW will be silly money, leaving english bits, and ebay. Ebay has Febi's at £125 a pair, or ATP at £60 a pair, had some ATP stuff before and it felt good enough quality, but didn't do any mileage on them.
    Have you tried quattrocorner aswell?
    • yodasfro
      • Apr 2006
      • 129
      Try CAC http://sites.internet.lu/folders/customautocraft/
      Austin
      1992 urs4 1991 200 20v avant 1990 90q 20v
        Originally posted by yodasfro
        Like Item A?: http://sites.internet.lu/folders/cus...htm#SUSPENSION PARTS
        • Thuppu
          • 4115
          Here in Finland when I ask for prices from a local parts store there was something like 10 different brands(30-120e/pcs) availablle of the rear control arms.
          • diesel des
            • 3896
            I have replaced these 3 times on my car. In my experience the cheap ones lasted no shorter than the one ones. Around 2 years.
            Sent from my GT-N7105 using Tapatalk 2
            • philj
              • Feb 2010
              • 377
              Nice to know, cheers. I went with the German ATP ones in the end from ebay.de. Fast delivery and couldn't fault the quality on visual inspection.
              • AndyP
                • 6049
                Got a link to the ones you bought? Looks like mine needs them too
                • AndyP
                  • 6049
                  Is there really any difference in LH and RH ones of these? GSF have RH ones in stock but LH are on back order but I can't think of a reason they'd be different.
                  • yodasfro
                    • Apr 2006
                    • 129
                    Yeah they are different L&R for cheaper ones I like optimal brand. Otherwise best to stick with the oe lemforder
                    Austin
                    • philj
                      • Feb 2010
                      • 377
                      http://www.ebay.de/itm/2-x-Querlenke...-/400281625073
                      Those were the pair I bought, turned up within a couple of days.
                        Originally posted by AndyP
                        .... but I can't think of a reason they'd be different.
                        One side is LHD/RHD thread and the other side is RHD/LHD thread so when you turn the adjusting nut in one direction, e.g. up from the back, it does the same thing on both sides of the car, e.g. more camber (or less camber). This will make sense if/when you take one apart (if you can get it apart).
                        Dave F.
                        • AndyP
                          • 6049
                          Thanks, ordered them Tuesday morning and they turned up today, quicker than most sellers in the UK!! I'll fit them at the weekend and let you know what they're like.
                          • AndyP
                            • 6049
                            Have you fitted yours yet Phil? Because mine didn't fit without modifcation
                            They have tabs machined on the end of the threaded bar to lock the two ends together
                            As you can see the tabs are machined in the wrong orientation. This is the std one on the left and the Ebay one on the right
                            I ended up cutting the tabs off so I could align them, then put some Loctite on the nuts to lock them in place.
                            • philj
                              • Feb 2010
                              • 377
                              That's a bit weird, fitted mine, was in a bit of a rush, and as all the fronts have been off so I'm going to get the whole thing aligned sharpish and didn't bother trying to set the camber. I'll have a look this week.
