C4 Front Poly bushes/ARB Blocks
  • Albert
    • 1500
    • Country: Poland
    #46
    Originally posted by Vorsprung durch Technik
    I have just measured my cars.I have 2 x S6 and a 2.8 30v Quattro all with Sports suspension and
    all 3 front sway bars are 28mm and incidently all 3 have a 17mm rear sway bar.Hope that helps.
    Thank you
    AKmotorsport.net - Manufacturing Motorsport parts that do the job. | Audi S2 on Facebook | Best way of reaching me is sending email to albert@akmotorsport.net
    • Wrath
      • Jan 2011
      • 779
      So 49€ is for one complete arm? Sounds like a nice price
      1995 Audi S6 - AAN (~350hp)
      2008 BMW 530xd (235hp)
      • Albert
        • 1500
        • Country: Poland
        #48
        yup
        • orignalS60
          • Mar 2015
          • 792
          • Home: Croatia Current: United States
          #49
          Does anyone know if the U.S. urS cars have the smaller 26mm bar.
          On ECS and gap it lists both sizes so I'm unsure. If vorsprung has
          3 c4's and they all have 28mm front bars I'm assuming they're all
          the same.
          • orignalS60
            • Mar 2015
            • 792
            #50
            Appreciate all of your work Albert. Next on the list some Fluro joint tie-rods
            or at least some 95a or delrin front tie-rod to rack bushings. For anyone interested
            Jared from Hersch performance in the states is making solid delrin transmission
            mounts, inner and outer diff carrier bushings, and rear diff mount. He's also making
            me a 95a snub mount for the 034 bracket and the delrin bushing for the apikol billet
            rear diff mount.
            • orignalS60
              • Mar 2015
              • 792
              #51
              It appears the s6 sedan is 26mm front bar and the s6 avant is a 28mm.
              Someone correct me if I'm wrong. I'll be looking into upgrading to the bigger
              bar if so.
              • orignalS60
                • Mar 2015
                • 792
                #52
                I need bushings for the toe-rods too.
                These below. They cost over $400 usd
                with stock bushings new.
                  #53
                  Originally posted by orignalS60
                  Albert do you think you could do these in 95a poly possibly:
                  I was hoping you could make motorsport version front and rear tie rods for the c4
                  like you made for the coupe but some 95a bushings for the fronts in the meantime
                  would be cool.
                  Also some solid delrin or aluminum transmission mounts, rear diff carrier mounts, and rear diff mount. I'm working with jared hersch from hersch performance on the above but he only uses delrin.
                  It would be cool to have solid billet aluminum tranny mounts and a rear diff mount.
                  Is this car going to be for the street or a very smooth track ?
                  Solid aluminium mounts for your gearbox and rear diff ?
                  Just askin...............
                  • Wrath
                    • Jan 2011
                    • 779
                    Original60: look here: http://www.ebay.com/itm/AUDI-REAR-LO...-/191136902333
                    443 505 171 F is the OEM number for the bushing without the arm...
                    • orignalS60
                      • Mar 2015
                      • 792
                      #55
                      @macspring it's not my daily driver just a fun/ track car. So I'm trying to get her
                      stiffened up to go take some turns. I also decided to skip billet mounts and I'm using
                      delrin mounts from hersch performance.
                      @wrath thanks for the info. I've been looking all over. It still would be cool to have a poly
                      option from Albert.
                        #56
                        NO worries, I believe you'll be better off, as too stiff is as bad as too soft. One needs to be fully grounded and fully independent while still listening to all sides, as this forum can cause others to be swept along further than they afterwards find they should have gone. btdt. Just sayin ......... for others benefit.
                        Kind regards.
                        • orignalS60
                          • Mar 2015
                          • 792
                          #57
                          Albert you can give us a preview of some
                          upcoming products?
                          • tommysporas@hotmail.
                            • Nov 2008
                            • 3
                            • Country: Norway
                            #58
                            28mm swaybar. ��
                            • Albert
                              • 1500
                              • Country: Poland
                              #59
                              upcoming products?
                              Front swaybar poli
                              rear swaybar poli
                              rear poli for the wishbones
                              • orignalS60
                                • Mar 2015
                                • 792
                                #60
                                Albert I Pm'd you.
