Suspension Woes Advice Needed
  • audinut
    • Jul 2009
    • 2195
    everything on the front of mine is new , drop links the lot - I have come to the conclusion im just gonna have to pull it all out and have a real good inspection
    NOT a car dealer! just an S2/RS2 enthusiast
    • irishs2
      • Apr 2009
      • 2455
      does that mean I too am upside down ? I went by how it fit, I didnt take note of the direction of the writing while fitting
      Eric
      95 S2 Avant under rebuild.
      • audinut
        • Jul 2009
        • 2195
        eric mine look like yours are now - and mine make awful noises
          You need to look at the springs irrespective of part number orientation. One end has the helix angle, the other is bent flat. The helix angled end goes at the top.
          • bilko0795
            • Feb 2011
            • 1883
            Originally posted by Error404
            inserts are loose by the sounds.
            Did you refit the spacer collars at the top that centralise the insert in the strut tube?
            I only had collers for the front inserts which I fitted and locked down tight. The rear inserts were touching the top of the tube and also locked down tight.
            Also the two front inserts were tight to get in I had to use a rubber mallet to get them in
            • bilko0795
              • Feb 2011
              • 1883
              Originally posted by Rusty
              Spring upside down.
              Andy that was my first thought the springs were put on with the tight coils at the bottom.
              • bilko0795
                • Feb 2011
                • 1883
                Originally posted by s2driveruk
                my H&R's have the close wound at the top and are silent on my coupe? I tend to find noises are usually tired drop links (or not nipped up enough) or the plate at the top which sits between the spring and the top mount is not seated properly, this allows the spring to rotate and make horrible noises , especially at the extremes of the steering rack, they kinda 'twang'
                That's the sound im getting from the n/s front a twanging sound the o/s rear clunking
                the o/s front is ok and the n/s rear clunking and im pretty sure the springs are all on tight coils at the bottom so I need to change them around only took me two days to do them
                  This is how I had them installed Ray - not a peep from them for 2 years
                  • mcandmar
                    • Apr 2004
                    • 5118
                    I'm 99% sure thats how i fitted them to my avant, but the coupes (blue springs) need flipped the other way around. Confused? So was H&R by the looks of it..
                    91CQ20v - Gone to a new home
                    93UR-S4 - The Magic Carpet
                    94S2Bus - The Emerald Express
                      You can see that the rears in error's post aren't seated properly at the top. If the fronts were sat like this, they'd twang. Q.E.D.
                        Springs upside down at the back is unlikely to cause any noise, as the struts don't turn. Suggest you check everything is tight.
                        Don't forget that the strut to hub bolts are stretch bolts and should be replaced, along with the nylocks.
                          That because the nuts were loose when the picture was taken mate, trust me I fitted them correctly, and had no issues at all with them
                            Done up or not, you can still see that the springs aren't seated properly and are at an angle due to being upside down. As above, it won't have caused an issue on the rear but would have done on the front
                            • bilko0795
                              • Feb 2011
                              • 1883
                              I have deffo put them on wrong will have to take all of again and I found some of the noise from the back it's the heat shield above the back box it's dropped and is sitting on top of the box so when a speed bump comes up its tapping the box also had a spirited run today and the car felt I was driving a boat nearly lost it on a bend but thanks to the brakes (Porsche gt3s ) I came out ok.
                              • bilko0795
                                • Feb 2011
                                • 1883
                                I have used the old bolts for now until tps gets some in was a bitch to get the bottom front ones out due to the caliper bracket getting in the way. I at to take the calipers of but couldn't budge the brkts and being aluminium couldn't put heat on them so i filed one edge of the bolt down until it cleared the brkt happy days.
