K24R Offset Top Mounts
Quick test drive shows a slight increase in harshness but not much. I have marked everything to assess if anything moves but so far so good. Steering is very positive and they fit the struts perfectly. Very chuffed so far. Only teething problem is that by moving the strut in the tower, the spring is just touching something on the driver's side - I think it may be a bracket holding the brake pipe, which is in a very will place...Leave a comment:
Fitted today
Amazingly, they went straight on with no fuss.
Will get testing and when I'm happy, I'll run a batch. Need to recoup the £800+ that the 4 prototypes have cost
Sorry chaps, work and family commitments have made getting things fitted any time soon rather tricky. Will do my best though...Leave a comment:
I'm interested in both a front and rear set. Don't need the rear strut mount as I already have a rear strut brace. No problem using the original strut brace in front?Leave a comment:
I'll design a front strut cap. For ease of fitting, I think 1 bolt per side would do it, otherwise, you've got to get the angles spot on...Leave a comment:
Looking really good. ill probably get a set of these off you at somepoint. I guess the rear ones would fit the front allowing me to fit a strut brace to my typ85 car and the front fit the rear as the typ85 doesnt need a rear brace?Leave a comment:
I know that feeling
Well looking forward to hearing how you get on with them
No, not sure when they will be as things here are busy and are only going to get busier.
Got the rear brake upgrade to fit too... And a window mech to rebuild and door cards to refit and subframe bushes to fit... Oh, and if course an engine to dismantle
Need a garage really.
