on my to work this morning I've notice a clicking noise, speeds up and slows down and is more apparent when setting off from a standstill, to loud to be a CV joint, any thoughts, Guru's.
Drive shaft clicking
Originally posted by BaS2on my to work this morning I've notice a clicking noise, speeds up and slows down and is more apparent when setting of from a standstill, to loud to be a CV joint, any thoughts, Guru's.
i have the same thing - seems more apparent after breaking hard to a standstill then moving off.
I can tell you (at the expense of ones pocket), its not the top mounts, wishbones bushes, subframe mounts, ball joints or CV - not sure if it leaves much else really but would like to know also...
imster
