The old girl's still pulling to the left! Hoped that a new set of top mounts and shockers might solve the problem but it hasn't. Had it all tracked and checked by Protyre in Bristol who are usually reasonably good and even got a print-out!
Current thoughts are a ball joint or binding calliper. Fronts are ok as I've jacked her up and made sure that the wheels are freely rotating but not checked the rears. Ball joints will have to wait till I get her on a ramp. Also, might try swapping tyres around just to see if they make a difference.
Any thoughts???
!Current thoughts are a ball joint or binding calliper. Fronts are ok as I've jacked her up and made sure that the wheels are freely rotating but not checked the rears. Ball joints will have to wait till I get her on a ramp. Also, might try swapping tyres around just to see if they make a difference.
Any thoughts???
I went home and loosened them myself, practically by hand. I don’t think he knew what the collar was. I’ve now got about two sides of the nut left on one side.
