Banging Noise Up Front
  • andys2
    • Dec 2003
    • 61
    caN ANYONE TELL ME WHAT MAYBE CAUSING A SLIGHT BANGING NOISE UP AT THE FRONT WHEELS. wHEN GOING OVER BUMPS I GET A SLIGHT RUMBLE LIKE BUSHES NEED RENEWING. cOULD THIS BE SUSPENSION BUSHES OR WISHBONE, IS THERE ANY OTHER RUBBERS OR BUSHES THAT MAY NEED REPLACING.
    CHEERS
    3B S2
  • Sidspud
    • 1223
    • Home: Scotland Current: United Nations
    I had a similar noise when going over bumps etc. It turned out to be a partially stripped thread on one of the drop links.
    I got a replacement, but never got round to changing it as the temporary fix of stacked washers seemed to cure the fault.
    ex '93 Avant owner
    • s2driveruk
      • 12696
      most of the rubber should be due a replacement if its never been done before on the S2. Bangs (i normally get them on the passenger side front) as this wheel gets the worst of the road, I'd guess a top mount on its way out. However if the rubber has been stripped from the wishbone metal sleeve then it can clunk and bang too.
      Best thing to do is to change balljoints, top mounts, wishbones and maybe even the subframe mounts too. Its amazing how different the car feels once they have been renewed.
      Good luck
      David
      1992 3b S2 Coupe
      • S2 Ant
        • 3682
        Has anyone got a price for the wishbones because as far as i can tell they are specific on the ABY and dealer retail is £76 each!!
        Ant
        2011 Kawasaki Z1000
        • s2driveruk
          • 12696
          sorry i meant wishbone bushes
          1992 3b S2 Coupe
          • andys2
            • Dec 2003
            • 61
            thanks lads, it turns out to be passenger top mount, i just got it changed. i think the drop link is also a bit loose but G & S never had any. top mount will cure most of the damage.
            • porkkis
              • 1994
              iT'S PROBABLY YOUR ANTI ROLL BAR LINKS THAT NEEDS REPLACING. yOU MIGHT ALSO WANT TO PRESS THE CAPS LOCK KEY.
              • s2driveruk
                • 12696
                gsf normally stock the front and rears.....or at least they did
                1992 3b S2 Coupe
