Wishbones & Wishbone Bushes
    Very soon, the weak point in my suspension will be the wishbone bushes.
    The car has pressed wishbones front and rear, which were replaced during my ownership. Although these are in good order, they still allow more fore-aft movement that I'd like.
    I'm looking at lots of options.
    Are cast front wishbones worth the money? I've heard they weigh a lot more.
    Poly or delrin bushes? Poly creak, which is a bit rubbish.
    Custom arms? ££££££££
    All experience gratefully received.
    Poly bushes don't creak if you install them with the correct lube
    I'm going to build some tubular arms for mine one day... but for now I have the forged arms which along with poly bushes are IMHO the best "off-the-shelf" option
    • V6quattro
      • Sep 2008
      • 949
      I try to make some of the bushes on my avant from delrin. Only problem is the lower rear bush on the rear suspension arm of the avant. Its not only moving up and down but also side to side. So i will use powerflex there.
      I don't have driven the car with the new bushes so can't tell you about that.
      • andy10v
        • 5996
        I am going stitch welded stamped arms, poly bushed.
        I believe the race cars that still used stock arms used the stamped arms (weight?).
        I would also rather bend a wishbone if I hit a kerb, than subframe or worse.
        The forged, and stamped arms also use a different sized bush, which is better, a bigger or smaller bush?
        Alex are you going to rosejoints when you go adjustable?
        034 do off the shelf adjustable arms;
        $360/wishbone
        $285/wishbone
        Plus the dreaded import etc
        Could you get some made up from a self lubricating material? Eg nylon, but I think that can swell up?
        Sold ABY-stock
        • andy10v
          • 5996
          Does delrin have any disadvantages?
          Sold ABY-stock
          • caterpillar
            • 2480
            cant use this then i need asymetric ones....and 3 screws in the balljoint...
              Those are the older ball joints designed for the much lighter Type 81/85 cars. Not suitable (IMHO).
              • martinws
                • Oct 2008
                • 917
                I stitch welded my pressed wishbones and run poly bushes on wishbones and ALU subframes mounts n I get no squeeks so far
                  Delrin is self-lubricating and hydrophobic, so doesn't swell, like nylon.
                  If delrin bushes aren't available, then that might be something to look in to then...
                  Poly wise, Superflex, Powerflex or other?
                  I've never had an issue with the stock wishbones and that includes some track abuse, so I guess anything stronger and with better axle location will be better.
                  Do Meyle or other do HD rubber mounts?
                    Superflex:-
                    Powerflex:-
                    What about something using spherical bearings?
                    • europeanme
                      • Oct 2005
                      • 3817
                      speak to Kev....he offered me a front set of top mounts with a spherical bearing in a while back to test for him....
                      • bikerjim
                        • Feb 2008
                        • 1028
                        SuperPro - http://www.superpro.eu.com/catalogue...1992/#SPF1428K
                        • bikerjim
                          • Feb 2008
                          • 1028
                          And PowerFlex Black Series - http://www.powerflex.co.uk/black-ser...Bush/8681.html
                            Powerflex state that the black series part is the same.
                            Mike, I think you've missed my recent topmount threads
                            • bikerjim
                              • Feb 2008
                              • 1028
                              Oh.... thats a bit daft?! lol
