I went to get my alignment done today. The guy couldnt shift the rear track control arms as they are seized. Im going to replace them. What are the best ones to buy and where from and id there a how to i can look over??
Tags: None
I got mine from http://www.allgermanparts.co.uk/ - Lemforder items.
The chap, Jason, was a pleasure to deal with and the service was excellent.Comment
Lovely ill get an order then. Has anyone got any pointers?
Its obvious how they atrach to the hub but how do they come off the subframe.?
Last question is everyone on this forum at work? Ha haComment
have new one in, and have the bolts and threads with wood tare....no prob next time to adjust or change them...Comment
Changed mine 3mths ago, bought mine from pete at q corner expensive though £90 each
also changed the bolts that fit them to the sub-frame, b-----ds to get out with out heat
Also reminds me to get mine four wheel alligned. No wonder i have ruined a set of rear tyres
I guess its only the adjusters that need freeing up the actual arms look quite new. Ill have to look and see. I just like to have all the parts ready for the jobComment
Having a look at the parts system. It looks like all you can buy is the complete arm so you unbolt from the subframe, then the hub and swap. I assumed they would come in bits. Looks like another 200 quid then.Comment
£65 each from Bestpartstore in Berlin
Imola B6 S4 AvantComment
