Front ball joints
  • 90quattrocoupe
    • Nov 2003
    • 771
    As far as the grease in ball joints and tie rod ends, there is a way to add grease thru the bottom. This is a way to insure there is grease around the ball. Hard to get in from the top by way of boot removal.
    As people seem to move away from forums to social media, one of the things that seems to become lost is DIYs and Tech Tips that were part of Forums. So...
    • 90quattrocoupe
      • Nov 2003
      • 771
      You can also replace ball joint and tie rod boots.
      • Waje
        • Nov 2016
        • 95
        • Country: Spain
        #33
        Originally posted by Lago Blue
        Waje,
        I'm not sure I understand your 1st question sir, but as for 893407366E, that P/N looks to be the earlier 'less centered' 3-bolt joint (for less caster) that may be correct for a 1990 20v Q sedan's pressed arm on the front axle. Link to 7zap's listing for this part:
        https://audi.7zap.com/en/usa/audi+80...407-37020/#17A
        To your 2nd question, perhaps not with this P/N joint, but the joint you require really depends on what car and what A-arm you may have. Perhaps this thread would prove helpful:
        https://www.s2forum.com/forum/technical/suspension-steering/2060841-3-bolt-ball-joint-versions-and-related-info-a-more-definitive-guide/page1
        My car is an S2 3b with solid arms, could you then tell me some way to give more caster ?? Thanks
        REGARDS
        • Lago Blue
          • Jul 2009
          • 843
          Waje,
          To replicate how the factory got increased caster with forged arms, use the two 'more centered' (a.k.a. B4 type) only knurled on top 895 407 365 A / 366 A ball-joints. See one in 2nd photo and description in Error's 1st post in this thread. If these are different (i.e.: less) in offset from what you currently have, then you will gain caster with their use.
          Regards also.
          • Waje
            • Nov 2016
            • 95
            • Country: Spain
            #35
            Waje,
            Regards also.
            And would it be possible to exchange the right with the left to win even more caster ?? Since that reference is the one I bought, but I am not sure if I will be able to mount them backwards, that way I would gain a lot of caster, which is very beneficial because, in addition, the steering of these cars is very soft and I would gain toughness. Thanks.
            REGARDS
            • Lago Blue
              • Jul 2009
              • 843
              Waje,
              Perhaps not without other obstacles, see 1st page of this thread, posts 11, 14 and 15 where A1QShip tried what you suggest. However, there may be other areas you can work to improve the steering response, for example inner tie-rod bushings, A-arm bushings and top-mounts (all known wear-items) are oft found neglected and if allowed to go soft / become internally torn, all will absorb surprising amounts of steering signal before any is transmitted, adding vagueness, numbness and imprecision (possibly also of interest, see Arm-Stops, Strut-Stops).
              Similarly, if the rear axle's A-arms can move fore-aft, due to weak A-arm bushes, and/or if the rear drag-link inner bushes are weak, this allows an inadvertent and random rear-steer behaviour which has a larger than expected adverse effect, since this axle has a long lever arm to work against the car's very forward C of G.
              Consider also that caster is but one measure at work here and cannot be altered without also changing other characteristics, for instance the inside rear wheel will lift more with a caster increase, something already an issue. So it may be that by first providing better full-time reinforcement for already achievable stock static alignment settings, gets one sufficient results when the car is in motion, as those settings are then better able to resist distortion / deformation / degradation and are better able to remain constant when really being pushed against; i.e.: tested dynamically.
              • Waje
                • Nov 2016
                • 95
                • Country: Spain
                #37
                Waje,
                Thank you very much for your indications. I take all that into account, in fact I will mount KW V3 with adjustable upper supports in a short time and then, little by little, I will change all the silemblocks to polyurethane, as I have been doing with some. But modifying the suspension ball joint is "cheap and easy", that's why I was wondering.
                REGARDS
