Power Steering Fluid Leak Fixed!
    Well I'm hoping I've finally got to the bottom of the fluid leak that has plagued me pretty much ever since I've had the car!
    There has always been some seepage around the T piece where the return from the bomb joins the return line from the rack. I always thought this was because the pipes were old and porous and figured I'd fix it by having new pipes made up.
    Well new pipes were finally made a couple of months back with high quality hose and to my horror the problem actually got worse. It got to the point I've been geting through a litre of G00 4000 every week or two
  • darkhorse1210
    • May 2010
    • 335
    Interesting, I've had a warning light come ona few times for that problem and have just topped up each time.
    Thanks for sharing
      Thanks for sharing with photos.
      Nice one.
      • State'd RS2 Coupe
        • 57
        Wow, nice catch. I recently overhauled the entire system (Pump, bomb, o-rings, banjo's w/ screens, fluid) and cross fingers all dry so far. High pressure line and T were both showing some leakage. Replaced O-clamps on T.
        My HP hose had some rubbing wear up at the radiator. HP hose is of course NLA, but available from Audi Tradition for like 230 Eur
        I cut off the gooey loose outer hose and re-wrapped the line with some industrial neoprene hydraulic wrap. Pretty easy to do and so far has done the trick.
        1990 Coupe Quattro, Full RS2 Conversion
        http://www.europeancarweb.com/featur...rs2/index.html
        2008 S4 Avant, Sprint Blue
        • s2driveruk
          • 12696
          just to note that the high pressure hose is now showing on Audi Tradition for (drum roll if you please......) €342.74
          They appear to as rare as rocking horse sh*t to be honest, so don't appear to be any places to get a new one from.
          **Thread resurrection complete**
          1992 3b S2 Coupe
            • Dec 2017
            • 5987
            A decent agricultural engineer will make custom hose sections for you if you take the old bits to them. Common job on a tractor these days.
              2014, seems like only yesterday
                • 4754
                Yep, frightening how fast time flies.
                • Lago Blue
                  • Jul 2009
                  • 843
                  Hi Newsh,
                  A couple of questions please sir, a) Was the subject fault the T (or perhaps Y-shaped?) -fitting itself that joins the hoses and was it repairable or was it replaced? b) I don't suppose you'd (or the mods and admin folk?) be able to restore the original photo from way back then would you?
                    Originally posted by Lago Blue
                    Hi Newsh,
                    Hi mate
                    It was the brass T piece that was poorly cast. The two parts of the mould were not properly aligned when the metal was poured in so there was an offset and a large witness.
                    Even clamped tight the hoses wouldn’t seal, it would have been even worse on the pressure side!
                    I dressed the part with a file to get the arms of the T round enough to seal and I’ve had no leaks since.
                    I’m not at home at the mo but when I am I will see if the pics of the part are on my old laptop. The PhotoPhuket account is gone.
