Why does my coupe keep wetting itself???
  • Monkeymagic
    • Mar 2012
    • 3419
    A few months ago I noticed that after standing for a week or so I started the car and my brake pressure warning went off. It had a ne bomb not 6 months before so I topped up my pas fluid. Then every time the car stood for a week or me I found a puddle of fluid under the NSF wheel. I spoke to Peter a Quattro corner as I suspected the bomb was faulty.
    He advised I had probably overfilled the reservoir and I should deplete the bomb before checking the level.
    The car has been fine for ages but has been stood for a couple of weeks whilst I await some bambridge top mounts. I stepped in the garage and the fluid had again leaked out the reservoir cap.. It's very little but it's there.
    I started the car and got the usual brake warning. I accept this as I feel this is normal whent the car stands for extended periods. But why is my power steering level rising and leaking out the cap vent.
    I haven't topped the level up cos after starting the car the level is still enough to keep the float up.
    Have I previously overfilled the fluid and it is leaking out once the bomb depletes over time, or do I have an issue.
    Ps the fluid was flushed and renewed when the bomb was done.
  • Monkeymagic
    • Mar 2012
    • 3419
    Oh and I get 30 plus pumps on pedal before the bomb depletes.
    • s2driveruk
      • 12696
      failed pressure relief valve in one of the PS lines maybe?
      1992 3b S2 Coupe
      • Monkeymagic
        • Mar 2012
        • 3419
        Wouldnt they only relieve pressure under working conditions? The steering all works perfectly.
          • 4754
          Quote from Monkeymagic..."Why does my coupe keep wetting itself???!
          Because the poor thing was locked in the garage and despite calling for dady "i need a wee" he had no choice but wet himelf.
          Sorry mate i could'nt resist that.I am sure you will get you own back on me someday.On a serious not i am sure you will get it sorted!! Terrible sense of humor
          • Monkeymagic
            • Mar 2012
            • 3419
            Ha ha.well she should be calling out " bambridge top mounts"
            I cant drive her at the mo as she is rattling her t*ts off... drives me mad.
              • 4754
              Ah the dreaded topmounts. They are annoying for sure mate.Think one of mine might have that problem.
                Look down the fluid res hole, there is a white tube with cut away sides the level should be only up to the bottom of the cutouts in the white piece.
                • Monkeymagic
                  • Mar 2012
                  • 3419
                  Ok ill check. Its about right then. But rises over a week or so....
                    Faulty check valve in the bomb IMHO
                    • Monkeymagic
                      • Mar 2012
                      • 3419
                      Yeah i thought that. But it was a new febi bomb at considerable cost. If it does it again ill be looking to get pete at quattro corner to replace. Notlike they are a tenner.... if it was leaking gas surely by now it would of ran out by now?
                        When you turn the engine on, the fluid level changes, so worth checking before and after switching the engine on.
                        • Monkeymagic
                          • Mar 2012
                          • 3419
                          it at the level once its been run. when its been sat for a week or more the level rises.
                            The only thing that can pressurise the PAS system with the engine off is the bomb. It should only pressurise the fluid downstream to the servo - that is its job of course. If the check valve is faulty it will slowly pressurise the fluid back through the pump to the reservoir.
                            • Monkeymagic
                              • Mar 2012
                              • 3419
                              Right after emptying the bomb roughly 30 depressions of the pedal the level rises just level with the cut outs in the filter basket.
                              When i start the car the fluid drops about 15 mm below the previous height.
                              As i said if it does it once more ill be taking it up with pete at quattro corner. Something is gradually creating positive pressure and it would.point at the only possibile. The bomb.
                              I dont hold out much hope of an exchange though as when i last spoke to him.he said the problem will be something other than the bomb!
