s2 struts on a urquattro
  • Skull
    • 3506
    • Country: Slovenia
    I used the search option, but i couldn't find anything about this topic.
    So, can the s2 suspension components (strut housings and hubs) be used on a urquattro?
    Any BTDT`s?
    Why?
    Because on that setup, you have the option of setting the camber where the strut meets the hub housing.
    I wonder if the axles fit the s2 hubs, how is it with the ball joints, if using s2 suspension changes the track.
    I need more camber on the rear!
    Thanx!
    Audi Quattro WR
    Ur quattro struts are stronger
    • caterpillar
      • 2480
      it will fit; you MAY change the outer propchaft unit....easy done...
      • robo
        • Aug 2004
        • 2086
        and allot hevier
        sigpic_________
        Rob
        • Ryss
          • Nov 2009
          • 233
          • Country: South Africa
          I did it on the front of may track car.
          Can fit bigger shocks and 3 bolts ball joint instead on 2 bolt. Much stronger. More camber and castor.
          You will also require ARB , lower control arms, Outer CV from an S2, and a new set of rims if you are using 5 x 112 hubs. B3 came with same config but 4 x 108 hubs.
          Not worth the effort for a street car, but major improvement for a track car.
          Regards
          Ryss
          www.autostart.co.za
          • PRA4WX
            • 50
            My urq project has all CQ suspension pieces.
            • Skull
              • 3506
              • Country: Slovenia
              Did you notice any track change?
              Audi Quattro WR
              • martinws
                • Oct 2008
                • 917
                I have full s2 running gear apart from gearbox under my type85 90q.
