I'm hoping to tighten up handling on the RS2 - would be interested to know what should on the list. I can't say I am well versed in the suspension/steering components, does anyone have a definitive list of wear items?
What I'm currently looking to do:
Shock/damper - stock rs2 springs, koni's. Fitted 40k & 8 years ago. Still good but I'm looking to replace with a KW V1/3 coil over, I want it slightly lower & firmer but still OK for light daily use
Topmounts - I have stock with Mance MSII'd to fit
Wishbone - recently replaced bushes with HD's
Steering - not sure what the wear items here are, guessing ball joints and track rod ends may be good to replace
ARB - stock RS2 fitted, intend to replace droplinks
I will also put some new (poly probably) subframe bushes on.
Current symptoms are a bit of a grinding/knocking feel on hard steering, particularly over bumps, can be felt through the wheel and more so through the pedals. There's a general vagueness and knocking at the front, typical worn top mount feel.
do up your lower arm bolts/nuts when car will be back on the wheels.
