no top mounts on the rear
Front suspension overhaul?
Thanks Jade - updated. Engine mounts came from Quattrocorner about 3 years ago.
I didn't realise the subframe bolts were stretch, I'll get a set of those, along with the hub-strut bolts too. I was hoping to strip it down a put a shopping list to get from Audi, I'm not really sure what nuts/bolts will need replacing, guessing more so on the rear than the front.AUDI - saving Dad's from minivans since 1994
I came across this thread which seems a good procedure to get everything off in the right order:
Strut removal
I think I missed a rather obvious point though... I don't need to compress the springs if I just take the complete strut, spring, shock, top mount assembly off? The spring will remain compressed by the slotted nut holding the top mount to the shock absorber.
Can someone just confirm that before I go and kill myself
Yes it will remain compressed if the nut is still onI came across this thread which seems a good procedure to get everything off in the right order:
Strut removal
1996 S2 ABY SilverComment
