Front suspension overhaul?
  • jade
    • Jan 2005
    • 1811
    • Home: New Zealand Current: Spain
    no top mounts on the rear
    RS 2 580HP
    • Ross
      • Aug 2005
      • 3399
      Thanks Jade - updated. Engine mounts came from Quattrocorner about 3 years ago.
      I didn't realise the subframe bolts were stretch, I'll get a set of those, along with the hub-strut bolts too. I was hoping to strip it down a put a shopping list to get from Audi, I'm not really sure what nuts/bolts will need replacing, guessing more so on the rear than the front.
      • Ross
        • Aug 2005
        • 3399
        I came across this thread which seems a good procedure to get everything off in the right order:
        Strut removal
        I think I missed a rather obvious point though... I don't need to compress the springs if I just take the complete strut, spring, shock, top mount assembly off? The spring will remain compressed by the slotted nut holding the top mount to the shock absorber.
        Can someone just confirm that before I go and kill myself
        • irishs2
          • Apr 2009
          • 2455
          Correct
          Eric
          95 S2 Avant under rebuild.
          • rynaqui
            • Mar 2012
            • 2752
            • Country: Malta
            #20
            Strut removal
            Yes it will remain compressed if the nut is still on
            1996 S2 ABY Silver
