ur s4 springs
  • chris
    • Jan 2008
    • 365
    ur s4 springs
    just changed from oe 3 purple paint springs on my ur s4 v8 to eibach sportline,
    not much of a drop but just enough,
    pics of the springs
    left to right original 3 paint purple
    eibach replacement
    kilein 200q front lowering spring
    and hr[upsidedown] 29921
  • chris
    • Jan 2008
    • 365
    urs4
    this is how it looked on the 3 purple springs, and then the eibachs, feels better and tighter, 3 purple springs are off to service my v8 3.6 saloon
      Looks good Chris. What are the numbers on the Eibachs?
      • chris
        • Jan 2008
        • 365
        ur s4
        used the kit,,e1521-140,
          Thanks. Any chance you can tell us (me) the numbers on the springs themselves?
          The reason I ask is my 94 S4 V8 avant came with some German aftermarket suspension installed and it is too low. I have a new Eibach kit for a V6 automatic avant (long story) and I am wondering/hoping that the springs in the box are similar to or the same as the kit you just installed.
          The problem with the kit numbers is the Eibach NAmerican kit numbers were different than the Eibach European kit numbers (for reasons I never understood), eventhough the springs in the kits might be the same.
          • chris
            • Jan 2008
            • 365
            ur
            i will get them tomorrow for you,,
            • chris
              • Jan 2008
              • 365
              ur
              number on the rear , 1521002ha, , fronts are even harder to see , but looks the same.
                Thanks Chris.
                  Chris: While I hope that you can confirm the front spring PN , I think they will (or should) be 1527001VA - which, according to the link below, should be for 5 and 6 cylinder, S4 with automatik and A/C and the S6 4.2L (DING!!)
                  The corresponding avant REAR springs are 1521002HA, as you have indicated.
                  Diese Seite wurde nicht gefunden, eventuell wurde diese Seite verschoben oder gelöscht und ist somit nicht mehr gültig
                  Now to confirm what is in the Eibach Pro-Kit box in the garage.
                    Originally posted by UrS4boy
                    ...Now to confirm what is in the Eibach Pro-Kit box in the garage.
                    Bugga
                    The fronts are correct as EW1527001VA *HOWEVER* the rears in the box are EW1517002HA (not 1521002HA).
                    Apparently the 1517002HA's are for the front wheel drive A6 auto air avants. The spring diameter is 13.0 mm instead of 13.5 mm for the 1521002HA and the unloaded height is 335 mm instead of 320 for the 1521002HA. Not sure how it would sit. Smaller diameter wire but taller winding to start with.
                    • wug
                      • Oct 2014
                      • 165
                      • Country: Romania
                      Instead of opening a new thread for a question i will post it here. Hopefully someone will help.
                      There are 2 different codes on Eibach pro-kit springs for urs4. Rear side: 1516002HA and 1521002HA. My car is Avant and is clearly specified 1521002HA Avant only. Usually Eibach prokit tend to sit a little higher on the rear. Do you think is a good idea to use limo code 1516002HA for Avant?
                      This are the number differences according to Eibach:
                      Execution designation 1516002HA 1521002HA
                      Identification progressive progressive
                      Outer diameter 123 mm 123 mm
                      Wire diameter 13.0 mm 13.5 mm
                      unstressed spring length > 310 mm> 320 mm
                      Total number of turns 10.0 10.0
                      UrS4 "PK Motorsport"
                      • wug
                        • Oct 2014
                        • 165
                        • Country: Romania
                        I guess i'll be the first to try. Will keep you informed.
                        Sent via Crapatalk
                          Just saw this thread / question, I think you're right to try the Saloon springs on your Avant, to allow the Avant sit more level at both ends.
                          Let us know how you get on.
                          Good luck.
                          • priba
                            • Mar 2015
                            • 108
                            • Country: Croatia
                            I know it's propably not popular solution among you guys but it worked for me just fine
                            cut one wind from the top on the rears ... top 5 windings are pressed onto each other while car sits on the wheels so they act more like spacers than the spring ... upper part doesn't have special finish like lower end
                            on the other hand, top mounts on S type are different than the standard Q and add some hight to the overall assembly
                            this is obviously not recognised by Eibach !?
                            third ... original springs have 7 - 9 windings depending on the suspension/car type so your 9 out of 10 will be just fine
                            I'm running 4 cyl. front version EW1515101VA now and it's same like my old 5 & 6 cyl. version EW1515001VA
                            replaced them with brand new just because old ones were all rusted
