Guys i need to get this sorted. I have been hanging on for some Bambridge top mounts but it seems they will be held up for some time. Ive looked at the 034 street density ones on line $50 dollars seems reasonable but the shipping is the same again and I guess I'll get taxed somewhere by customs. Does anyone know if they are available from UK suppliers?? I need to get the coupe out asap and If needs be Ill be fitting OE but want to save the hassle long term.
Top Mount Saga continues
Tags: None
I removed some 034 voidless ones from the rear of my car, where they've done about 5k miles and are still in excellent condition. Cost me £50, so £25 delivered
I've been giving my new design some testing and have done about 500 miles so far on all sorts of roads and they seem to be doing very well. I do need to try some slightly freer moving bearings at the front but the overall feeling is very positive with a tiny increase in NVH... When I get a chance to get the offset solid subframe mounts in the front, solid ones in the rear, poly wishbone bushes and new balljoints, I'll be able to give feedback on the whole setup
The downside though, is potentially £300 a pair
The development ones will be £1k for 4 by the time I replace the bearings and get the rear strut brace made properly. Still, it's something that I've wanted to do for years and I'm very pleased with the results for about the same as some imported ones from the US.
1994 ABY Coupe - Projekt AlpinweissComment
check your ARB rubbers, drop links as they are the usual suspects or even check that the castle nut hasn't loosened and allowed the spring to move aboutsigpic
1992 3b S2 CoupeComment
I have read this thread and it's definitely interesting but can any of you guys explain what is wrong with oe ones? How long would you expect oe front top mounts to last?? I have recently bought RS2 blue top mounts as they are supposed to provide better handling and last longer. Your thoughts/advice appreciated please.
99 2.8 final edition CabrioletComment
Basically a flawed design, green and blues suffer from the same issue, the mount collapses and in essence, you can treat these as a consumable item with little change of getting more than 5-10k miles max from them. Typically they start to deteriorate after only a few months
Can anyone recommend some top mounts? I am about to change mine, they've been on for about 3 years and have started to knock....sigpicComment
One of the many reasons why, I'm leaning towards the C4 chassis.
Also I can't weld / fabricate, as if I could I'd cut the towers out of my B4 cars and raise them up to lower the car on standard springs and it would allow me to have a better style of top mount.
Sorry mini rant over.
So when these were new cars and under warranty Audi must have done there nut replacing these top mounts.I just don't remember this problem being an issue back then and I used to buy all the car mags. I well remember the B5 ign coil issues. I have changed these top mounts once before but didn't do many miles in that car after the change as it was a 3 rd car but do remember what a big improvement it made with all new gen Audi suspension parts. How about some clever person on here looking at other sports orientated cars from other manufacturers that have proven top mounts and available for a reasonable price. Mercs were well known for isolating the road surface from sensitive ears and fragile bottoms. Just a thought.Basically a flawed design, green and blues suffer from the same issue, the mount collapses and in essence, you can treat these as a consumable item with little change of getting more than 5-10k miles max from them. Typically they start to deteriorate after only a few months
