The shock shaft does ride on the bearing, as the bearing rides on the spring seat, which is seated on the shock shaft with a large nut retaining it.
There is nothing different in how the MKIV and B4 mounts work, the shock does not take direct loading on either set-up unless the shock bottoms out, in which case your shock and top mount are ****ed either way. In normal operating conditions, all of the axial load through the shock shaft is transferred from the spring, through the spring seat.
I don't want to insult you, but I have bearings and MK4 perches at home. I know how they work.
