Anybody using kw variant 3
  • PRY4SNO
    • 767
    I have already, they're begging to be installed
    2013 Touareg TDI /// #farmenwagen
    • mac2226
      • Jun 2008
      • 1289
      Please pm me when you have them fitted and let me know how they handle thanks michael
      • Ross
        • Aug 2005
        • 3399
        Not quite relevant as they're for the RS2 but I have a set of V3's begging to be fitted... still trying to get all the old stuff off the car just now and building of the new struts ready to install.
        • PRY4SNO
          • 767
          Im on the fence about swapping the springs front to rear...
          I dont like how these cars tend to push but I also want to avoid snap oversteer when I hit a bump or freeway expansion joint.
          Have an rs2 front bar and a stock bar in the rear, going to eventually add a 4kq front bar to the rear if I can't find a Whiteline.
          • mac2226
            • Jun 2008
            • 1289
            Rs2 farb would be nice to go on front and s2 coupe farb on the rear with my kw variant 3 coilovers on coupe
            • Sonic
              • Jul 2006
              • 5514
              #21
              Originally posted by mac2226
              Thanks rusty do you know if sonic has the front Antirollbar at back as well?
              Originally posted by Rusty
              Not sure, I think he has a Whiteline.
              Best setup is to get the higher rated kit, swap the front and rear springs (harder springs on the rear) and run a white line at the rear with stock front. Gives adjustability and a bit of compliance at the rear when compared with the FARB option.
              Yes im running v3's with springs in normal positions, not front-to-back, with RS2 FARB and whiteline RARB.
              The back is still a little skittish in mine under heavy corners or braking, this could be due to the rear brake upgrade i've just fitted but i'd like to swap the springs around as Rusty and Error404 recommend to test.
              S2Forum.com Administrator
