Camber Bolts
    Camber Bolts
    Anyone used them or have any opinions on them? Not sure I'm convinced but it's them or slot the struts...
  • mike74
    • Apr 2014
    • 615
    I've not used them personally but have heard mixed reviews. Apparently some of the cheaper ones can slip, throwing adjustment out. Personally I would rather slot the strut and use manly bolts torqued up properly to fix it. Its horses for courses though, some might be ok
      Would only use Eibach or Whiteline.
      • AndyP
        • 6049
        They are standard fitment on the Porsche 944S2, I've often thought about getting some and seeing if they could be adapted to fit the S2.
        • s2driveruk
          • 12696
          didn't H&R do these too?
          1992 3b S2 Coupe
            Last time that I slotted some struts (on a vauxhall nova GpN car) - we got the angles where we wanted them, then welded the washers onto the strut so it couldn't be adjusted.
            • afterburner
              • Mar 2012
              • 246
              • Country: Bulgaria
              Or you can use some sort of WRC style camber adjustment washers. This gives you the ability to change camber easily, on the track by having a set of different washers. Something like this:
                Where does that lot go? Strut or wishbone?
                • afterburner
                  • Mar 2012
                  • 246
                  • Country: Bulgaria
                  The round ones go on the struts. You can see that they have holes with different offsets on them. You have to weld a metal piece there that surrounds the washers so they just slot in it like a piece of a puzzle. That way they never move and the only thing that changes when you replace them is the hole that locates the bolt.
                  • s2driveruk
                    • 12696
                    1992 3b S2 Coupe
                      Check how much clearance you have between the tyre sidewall and the steering arm... bet its only a few mm at best
                      FWIW I would slot struts and bollock them up tight with 12.9s
                        I think the correct technical term you are referring to is "TAF" !
                        • TimE-J
                          • Jul 2009
                          • 1292
                          Certainly a well known technical term.
                          96 S2 aby Coupe. Rebuild Project
                          96 mk3 golf tdi daily.
                            Yes if you tip then inwards then you'll need bigger spacers.
                            • here2learn
                              • Feb 2012
                              • 325
                              what about adjustable top mounts
                              i have only seen the time attack avant use these so far,other build threads i read use these more often than not.
                              on our cars i guess this is an irreversible mod but the volume and precision of adjustment surely spanks at a one for all mod.
                              Due to all the top mount issues i have read about with rusty producing the only lasting fix,non adjustable caster subframe mounts and camber mods,the steering rack in an awkward position.
                              i could well be wrong but without mistakes you are unable to learn
