PS Cooler Pipe Split...
  • RustyNut
    • 1433
    • Home: Zambia Current: United Kingdom
    It appears that my PS Fluid Cooler Pipe has a very small split or hole in it... It's right where the bracket holds it in place about half way along the ribbed section. Is this a common fail on these cooler pipes? I'm glad I've found it but not so glad about what they cost from the steelers... If anyone has one that they're looking to offload could you reply or drop me a pm please.
    Russ
    Old Stuff Reborn.
  • Rusty
    • 18953
    I thought about using a 4 row oil cooler.
    • RustyNut
      • 1433
      Not a bad idea. It's on the low pressure side so can't see why not and the mount would be easy to adapt.
      Old Stuff Reborn.
      • Rusty
        • 18953
        Maybe not for your OE+ build but that track car you'll get some time...
        • RustyNut
          • 1433
          Ha, I think I need my old 90 back...
          Old Stuff Reborn.
            Andy10v found his came apart the other day. They are getting to be a more common failure unfortunately.
            On your car Russ, I'd get a new genuine one while you still can. If it wasn't such a special motor, small generic oil cooler like Andy suggested would be fine
            • RustyNut
              • 1433
              Definitely going the genuine route, just don't like what it's going to cost me... Hoping someone here has a new one they don't need. If I can't get a new one I may have to go with an alternative solution..
              Old Stuff Reborn.
                They are pretty common on B3/B4 cars. Why not get one and keep it with your original parts stash and go aftermarket. I've been thinking about it since Andy's split last week.
                • Trist28
                  • Dec 2008
                  • 725
                  I may have some of these. Ill check tomorrow.
                  How much are the stealer's asking??
                  • Rusty
                    • 18953
                    £50-60 or so for a small cooler, fittings and hose.
                    • 220bhp
                      • 2578
                      I thought you said ps cooler pipe the corrugated pipe from the power steering pump.
                      • RustyNut
                        • 1433
                        Yes, that's the one i'm after. The dealer wants £124.00 for a new one and they're on a two week delivery!! For what it is i'm not forking out that much. Really hoping Trist28 has one otherwise it's going to have to be non standard. However, is fitting an oil cooler tried and tested and do we know of any car that's running an aftermarket cooler? I'm just wondering if it affects flow rates?
                        Old Stuff Reborn.
                        • TimE-J
                          • Jul 2009
                          • 1292
                          I'm almost 100% sure its this cooler pipe thats leaking on my s2 as well, let us know how you get on finding one although a small cooler does sound like a neat idea.
                          96 S2 aby Coupe. Rebuild Project
                          96 mk3 golf tdi daily.
                          • Rusty
                            • 18953
                            Russ, we can always design a finned pipe to do the same job.
                            • Rusty
                              • 18953
                              There are inline coolers I can find in the US but not in the UK just yet...
