looking for theory or fact as to why my wheels dont catch inner balljoint
  • GazzaG60
    • 4133
    guys
    i have fitted s2 arms and balljoints, subframe and run currentyl 16v shocks drilled out to m14.
    i have s4 avus 17" wheels which iirc are 47et.
    why do they bolt straight on and not catch the inner steering joint with 235 45 17 tyres. its mm off but it seems everyone runs about A 10mm spacer and my s2 ran et 35 again 8" rim
    what have i done wrong? it all bolts up right. maybe a fraction of negative camber?
    any ideas appreciated.
    Check the wording of your post, as it appears confusing to me ?
    • irishs2
      • Apr 2009
      • 2455
      I take it the steering arm is at the same angle on the uprights as it would be on the S2 uprights?
      And you can steer from side to side full lock without binding anything.
      I suppose by drilling out the arms, you might have given yourself a better angle / camber than stock.
      I could be talking complete rubbish too
      Eric
      95 S2 Avant under rebuild.
      • GazzaG60
        • 4133
        sorry if wording is turd. its what comes from a confused head. ill try to simplify
        basically i have s2 setup up front with 16v shocks which have to be drilled out to fit the s2 hubs. so basically s2 coupe car on a saloon b3. i have a set of b4 avus wheels like the s2 but the slightly newer design in 17". i think the offset is 47et. tyres are 235's
        everybody ive seen has to run a spacer but min bolt up and clear the steering joint and shocker. the wheel spins freely. camber looks a little negative (if thats right). wheel out more at top than bottom. ball joint is positioned exacly as on s2. i have just bolted the arm straight on.
        what have i done wrong. i presume something is wrong? if i go narrower on tyre say 215 im sure i can get some positive camber in by messing with the shocker bolt positions. maybe running the drill through again.
        but why does the wheel fit and not need a spacer? im worried something is not right
        does that make sense?
          Yeah you have some range of adjustment between the hub and strut, sounds like you are adjusted right out at the top, meaning you have positive camber. You'll probably find you can't get it aligned properly without a spacer and adjusting it back to where it should be
          • GazzaG60
            • 4133
            sounds likely.
            why would this be? due to my drilling or just the shape. better check the bolts too.. hows it adjusted? the bolts are normal bolts on our cars?
            i expect you may be right though. i may be able to get the wheel under the arch slightly better too if its more in at the top. ive got about 5mm at the moment maybe a fraction more at the top to spare on this wide tyre.
            do they do camber bolts for our cars? would make life easier. stock bottom bolt camber top bolt?
            • GazzaG60
              • 4133
              anybody used any of these
              http://www.ebay.co.uk/itm/Mitsubishi...-/371066644091
              • GazzaG60
                • 4133
                or these even
                • europeanme
                  • Oct 2005
                  • 3817
                  Originally posted by GazzaG60
                  to be honest I did look at these but couldn't see the improvement/benefit would be that great for my set up....I would be interested to hear how you get on if you decide to try them....
                  • MattS2
                    • Apr 2006
                    • 657
                    Are the wheels genuine or reps with a 35mm offset?
                    Ex owner of a 1993 Silver Avant - RS2 spec.
                    2002 A8 sport 2.8 quattro Sold
                    2003 A6 Avant Tdi
                    Mk Indy 2.0 pinto circa 160 Bhp
                    2004 VW Caddy SDi
                    2002 Civic Type R
                    • GazzaG60
                      • 4133
                      they are original ronal avus stamped. audi rings on them inside. 45 et i believe. 17"
                      are there more than one size of these anybody know?
                      • andy10v
                        • 5996
                        S6 avus wheels are 17x8 et 35, much rarer than the S4 wheels which are et 45ish.
                        I got S6 wheels as they are bolt on without spacers (depending on tyres)
                        Sold ABY-stock
                        • GazzaG60
                          • 4133
                          they do a et45, et43 and et 38
                          mines a 45, the normal ones
                          • GazzaG60
                            • 4133
                            maybe its the fact its a 7.5" rim and not 8 according to etka
                            • GazzaG60
                              • 4133
                              ok think im getting somewhere, thanks guys
                              ordered some camber bolts, PFA100-14. gonna go with some 215 tyres i think. its on 235's and they balloon over the edge of the rim about 1.5cm at the moment
                              should do the trick, i hope.
