Right way up oem springs?
  • bertman
    • Apr 2007
    • 1173
    • Current: United Kingdom
    Having a blond moment so this might be very self explanatory if you know.
    What is the correct orientation for the springs.I have read that the coloured spots should sit on the bottom of the strut and then read somewhere the flat part of the spring should sit at the bottom putting the spots at the top.
    So which one is it??
    Rebuilding my suspension this weekend so everything is coming off
    Rob
    Ragussa green avant RS2+ spec
    Racing blue Octavia VRS mk2 estate-Remapped now to 250 bhp
    Audi coupe gt-slow as hell but loads of character-sold
  • s2driveruk
    • 12696
    ...off the car I hope...no need to strip because you're stripping the suspension
    1992 3b S2 Coupe
    • bertman
      • Apr 2007
      • 1173
      Actually David I love working on the car butt naked
      Gives the neighbors lots to talk about
      Rob
      • andyg plym
        • Nov 2006
        • 4646
        I've done mine a few times and if you look closely one of the ends has a flat edge, this goes on the bottom end .
        I once made the mistake of putting one in upside down and it knocked it's tats off !
        • bertman
          • Apr 2007
          • 1173
          well just went out and checked with the spare spring i have and having the flat bit on the bottom would put the coloured spots at the top of the spring,which is in fact the opposite way to they are now.
          This might account for the knocking I have been trying to find for a long time
          My mate a long time mechanic said they should go with the part nos the right way up
          Rob
          • andyg plym
            • Nov 2006
            • 4646
            Yes spots towards the top, I recently unlowered mine and remember it being like this, mine does not knock at all
              Looks like you've found your answer Rob!
              • bertman
                • Apr 2007
                • 1173
                Lets hope so John,one less thing off the list!
                Rob
                • bertman
                  • Apr 2007
                  • 1173
                  Right finished,all four shocks replaced (thanks to my wife for an early birthday present)with some billies.Springs now the right way round (I hope)
                  Avant rear suspension is so easy to remove and work on.Now for a test drive and hopefully no knocking but at least i will have improved handling-Now for a well deserved beer
                  Rob
                    • bertman
                      • Apr 2007
                      • 1173
                      Do these shocks settle in after a bit?,I have been told they even out after about two weeks of running the car.
                      The car itself is sitting a bit higher and yes I did do the spring perch mod on the rear and dropped it the recommended 20mm but looks a little higher than usual.I will wait till I give it a run.The beer came before test drive
                      Rob
