Whilst reverting my RS2 to stock springs I discovered the upper inner arm bushes were all looking very tired, two of them just feel out. So I got a quote from TPS for the correct 8A0505185A B4 bushes, they're £28+ VAT each and I'd have to wait a couple of days for them. Oh yeah and get this they could only supply three, that's a lot of bloody use!
So I ordered up four 8D0505185A B5 quattro bushes which as far as I can see are the same item only £14 + VAT each and in stock.
They fit perfectly.
One of the old ones.
The new B5 items fitted.
Note, one needs to be careful removing and fitting the bushes as it wouldn't take much to bend one of the pressed arms
They fit perfectly.
You have a Pm.
. I know mine has the MTM conversion but that's part of it's history and I'm going to refresh the components they changed and leave it in place. I like the set up so much I have another set of identical chips waiting for when I convert my S2 to an ABY ECU. Going for a K26/7 on that car and the MTM software will be perfect for getting her running right before upping the boost somewhat.
