While I'm waiting for the Avant urethane rear subframe bushes to come into production I need to move the car so I can use the garage. Bushes burnt out - see the issue!
Who makes the solid alloy ones? Or does anyone have a set for sale?
As I cant attach images to messages - I've put this here
Hi Albert
The bushes arrived today thanks - I have 2 boxes - each with different bushes in. An S2 avant rear subframe requires the same height bush each side to match the original if using same length bolts - Or can you confirm there is an extra 1cm to accommodate the reduced height on the bolt side bush. I don't want to risk problems with the captive nuts thats all. I guess I could cut the bolt but would rather not.
