Advice needed. Which of these sub frames will fit an RS2?
IICRC, In my research the subframe from the 2.8 litre 80 is the same as RS2/S2 ABY.
Agree. The B4 Audi 80Q with the AAH 2.8L V6 came with either the CBR, CVX or CPN five speed transmission. The subframe for this combination was the 8A0199313BC which is the same as the one used for the RS2 and its CGR and CRB transmissions.
only difference I have ever found is some v6s have some extra reinforcement on the inside longest bit where its spot welded together which I have heard causing the downpipe to catch when used on a aby/adu
non of those in the pictures have the reinforcement
from breaking a few v6s it appeared to me that only earlier v6s had the extra bit
