Keen to make this a STICKY for UrS6 owners on here and have one definitive suspension settings / alignment thread.
Quick questions.
Are the factory recommended settings different if you have different sized wheels and tyres fitted - i.e.
205/55/16 on 7.5 x 16 Avus rims
or
255/40/17 on 8 x 17 'plus' rims
Personally I'm looking for specs for a road salon car on Mk1 S8s with 255/35/18.
Also tyre pressures for this set up ?
Also are the factory settings different a 2.8L V6 and a 2.2L 20vt different, assuming both on the 16" rims and matching tyres ?
Also is there a different in settings for a saloon and an avant ?
Thanks for your inputs.
Quick questions.
or
) a matter of personal taste, i.e. more front camber because you drive the twisties agressively or more toe-out because you like a quick turn in. The values that I presented are a range, not chiselled in granite. (If you're from Aberdeen, then that *COULD* be a joke
