heavy shaking at 80 on a bend
  • MGaz
    • Feb 2008
    • 698
    My C4 A6 quattro avant was having a little shake through the steering wheel for a while and i just thought it was wheel weights .
    But today I over took someone and just popped to 80, while on a very slight bend and the whole front of the car started shaking and the steering wheel was bouncing up and down more than ive ever seen a steering wheel bounch in my life!
    Then, slowing down to 60 it goes away. I know what wheel weights feel like,.. but this felt more like the wheels were going to fall off!
    Anyone had this before?
    Something does sound a little loose/thud type sound/feel while going over severe bumps in the road..
    I'm almost affraid to drive it, it feels that bad at 80
    C4 A6 AEL avant quattro: daily
    TYPE-85 Coupe Quattro: clicky
    2.5L GTi engineering RE2500 190hp.180lb
    Schrick 272 cam
    C A C 2.5" T304 Exhaust
    ITG filter
  • Rikki Kitto
    • Feb 2010
    • 6276
    Check the obvious first, loose wheel nuts, hub bolts, ball joints, suspension struts, tie rods etc then swap wheels around see if it changes things, tyre pressure and condition can cause this too. I had similar last week was a knacked ball joint
      We had a tyre on my mate's Audi 100 that was worn out of round, similar symptoms.
      Also check wheel nuts BTDT, thought it was a bad CV
        Simplified C4 Lower Control Arm Replacement DIY
        As the others have said but I suspect worn lower control arms, either the bushing at the subframe end or the ball joint at the strut end.
        This could help:
        • bluequattro
          • 2960
          I'd say control arms too
          Does it do it on all roads?
          Maybe it was to road?
          • diesel des
            • 3896
            My urs4 did exactly this when a front damper had burst.
