Leaking PS pump.
  • John.
    • 2615
    Leaking PS pump.
    I know it'll have been mentioned before but......
    That plastic screw in plug on the pump, mines leaking from here. I haven't touched it yet, but is it likely to just unscrew to reveal an o-ring that I can just replace then refit and it'll live happily ever after?!
    Cheers,
    John.
  • jade
    • Jan 2005
    • 1811
    • Home: New Zealand Current: Spain
    Cheers,
    John.
    No... You need to buy the kit, plug and oring other it will just blow out again
    RS 2 580HP
    • John.
      • 2615
      Got a link to what I'll need please?
      • andy10v
        • 5996
        The big X one?
        If so 026145541 for the plug and seal.
        Sold ABY-stock
          Leaking X-plug on the top of the Power Steering/Power Brake Pump
          That X-plug is metal not plastic:
          "The X-plug has an O-ring which eventually gets eaten by the PS/PB Pentosin fluid in the plug. You can try tightening it to stop the leak but that might not work.
          Here is the pump in its native habitat, showing the X-plug.
          Photo courtesy of Steve M.(Boxflares) from his PS Pump R&R DIY
          If you decide to replace the X-plug you need to replace it with a dealer-only part (aftermarket O-rings might not last long in the Pentosin). To remove and tighten the X-plug you will need a drag link socket. The new X-plug and O-ring are as shown here:
          Example Drag link socket:
          Might need the corners filed off to fit down into the X-plug
          How our Power Steering and Power Brake Pump Works from the UrS System and Chassis Map:
          Reference: http://forums.quattroworld.com/s4s6/msgs/172476.phtml
          • Michael S2
            • Dec 2011
            • 1378
            I think I have a spare seal you can try first if you want John
            1995 Audi S2 Avant
            • John.
              • 2615
              Thanks all for that, I thought it looked plastic!
              I'll just get new one from TPS (thanks for the offer Mike)
              Was looking at the PS rebuild sticky thread.....I'm assuming there's a spring behind the plug??
              • John.
                • 2615
                Have ordered from TPS
                Who uses what instead of a drag-link socket?!
                • domas
                  • Oct 2014
                  • 307
                  • Country: Lithuania
                  I have removed my pump to get it rebuilt in the hydraulic shop
                  in the end i had to get another one as the housing had a hairline crack in the housing, which was found out only after it was rebuilt. So it is also a possibility
