subframe poli bushes dimensions
  • ACQ
    • Jun 2008
    • 141
    • Country: Lithuania
    Maybe someone has dimensions of polyurethane/aluminium bushes for front and rear subframes? car is audi coupe quattro typ85.
  • _ShurikeN
    • Mar 2010
    • 733
    • Country: Russian Federation
    There's a well known sketch:
    Your center holes should be 10 instead of 12.
    • ACQ
      • Jun 2008
      • 141
      many thanks. 12mm to the subframe hole length? looks like it must be longer, but if you made bushes by this drawing and they fit so I will trust
      • _ShurikeN
        • Mar 2010
        • 733
        10mm and 12mm are center hole diameters for subframe bolts: early and later versions depending on cars.
        Actually, I can't confirm anything yet. I did not have such bushes made personally for me by this sketch, but I have bought ready set made of steel. I can measure my washers.
        • ACQ
          • Jun 2008
          • 141
          I didn't mean center hole, but place where is 6mm lenght in drawing
          • _ShurikeN
            • Mar 2010
            • 733
            Ok, I see. Unfortunately I don't have the exact inner height of subframe hole. I might have some rubber bushings to measure. But It may be faster if you buy а cheap rubber bushing for yourself.
            Btw, i have had a look at my metal washers yesterday night. They are quite the same as on pictures except outer diameter being 48 not 50. Affects nothing actually.
            • ACQ
              • Jun 2008
              • 141
              Still looking for dimmensions
