Maybe someone has dimensions of polyurethane/aluminium bushes for front and rear subframes? car is audi coupe quattro typ85.
subframe poli bushes dimensions
10mm and 12mm are center hole diameters for subframe bolts: early and later versions depending on cars.
Actually, I can't confirm anything yet. I did not have such bushes made personally for me by this sketch, but I have bought ready set made of steel. I can measure my washers.Comment
Ok, I see. Unfortunately I don't have the exact inner height of subframe hole. I might have some rubber bushings to measure. But It may be faster if you buy а cheap rubber bushing for yourself.
Btw, i have had a look at my metal washers yesterday night. They are quite the same as on pictures except outer diameter being 48 not 50. Affects nothing actually.Comment
