Ur s4 power steering help please
  • roysterFR
    • Dec 2010
    • 140
    I am having real problems with power steering in my Audi 100 s4. I fitted a new steering rack and things were fine then pump started making bad grinding noises, I fitted a new one and still the same and I am now on my 4th attempt- I had known good ones and it is still making a noise almost exactly the same, I fully bled all before running and then bled steering after. Does anyone have any idea if there could be a restriction etc? I checked filter bolt and was fine and has all new fluid. Am dreading having to change rack again as I already had to change out dodgy reconditioned unit.
  • Pirvu Eugen
    • Apr 2007
    • 1978
    • Country: Romania
    Is making foam in the tank?
    Iff yes...is sucking air through somewere.
    Goodluck!
    • roysterFR
      • Dec 2010
      • 140
      Goodluck!
      No no foam in tank that looks ok, cheers
        Does the PAS work correctly? i.e. is it just the noise from the pump?
          Original pipes? Or did you get some made up?
          • roysterFR
            • Dec 2010
            • 140
            Original pipes which look ok? To be honest I think steering is also stiffer now to turn, it was better when rack first went in with original pump
