S2 struts any difference?
    • 4754
    Can anyone tell me if there is any difference between front S2 Avant and front S2 coupe struts? The lower bolt holes are M14. cheers guys.
  • bluequattro
    • 2960
    Same as far as I'm aware
    • AndyP
      • 6049
      The avant ones are different, those ones you've just bought are no good to you, I'll give you £20 for them
        • 4754
        Yeah pull the other leg it's got bells on. These will do very nicely for my V6 avant.
          • 4754
          And as Andy10v is sewing possible seeds of doubt this being S2 forum
          with loads of gurus on here,would be nice if some of you would chime in.
          • AndyP
            • 6049
            I thought they were the same, I'll check part numbers on ETKA.
            • AndyP
              • 6049
              94 ABY coupe - 893 412 033E
              94 ABY Avant - 895 412 033F
              Not sure what the difference is, I still think they will fit
                • 4754
                I did try and check on vacate but it's down atm.
                  • 4754
                  Thanks Andy . Thinking about it probably the spring? What do you think? Good find for me these and hoping will be perfect for sorting out the V6 with better S2 handling stuff. Slowly slowly catching the monkey.
                  • andy10v
                    • 5996
                    S2 coupe and S2 avant front struts are the same as far as I know, early cars can have smaller holes, but as long as you match them up you are good.
                    I have not even been here yet
                    Use this instead of vagcat, it is much clearer
                    http://audi.7zap.com/en/rdw/
                    Sold ABY-stock
                    • andy10v
                      • 5996
                      Or did you mean springs and shock differences as well?
                      Sold ABY-stock
                        • 4754
                        Must be my age eagerness and not checking.
                        Sorry Andy,mix up between you both.
                          • 4754
                          Well it would be nice to know what i have/am getting,to coin a phrase "overthink it" no seriously it would be nice to know as the V6 is an avant so i'm thinking S2 avant will be slightly heavier duty due to load carrying ability.
                          The main thing is i have the 55mm diameter S2 tube and the later M14 bolt holes meaning it should all just bolt straight up on the V6. Thats the theory.
