Tool for Front strut cap nut
    After a lot of googling I can track down the special long pipe/box socket (29mm) with 1/2" drive to be from KLANN. It used to be available from the mother ship as the VAG2069.
    Specifically it is the KLANN KL-0050-1
    Unfortunately I cannot find one in Europe anywhere. Anybody got ideas for alternatives - other than having something custom made ?
    I have tried to schwing the nut off before with a good stilson wrench and scaffold pipe but that thing is on tight.
  • John B
    • Apr 2008
    • 926
    Hi Paul
    You can buy or borrow mine if you like
    JB
    2001 996 C4 - Being renovated
    1994 ABY Coupe - "Das Smaragd RS2+ Coupe" - Sold
      • 4754
      I bought My 33mm version 2069A tool of Ebay DE a couple months ago,keep looking they usually come along eventually.
      Edit unless you can borrow the above one.
      • mcandmar
        • Apr 2004
        • 5118
        There are plenty of options on flebay, though i always just knocked them off with a hammer and chisel.
        http://www.ebay.co.uk/itm/351224466535
        http://www.ebay.co.uk/itm/290958019050
        91CQ20v - Gone to a new home
        93UR-S4 - The Magic Carpet
        94S2Bus - The Emerald Express
        • Mikes2
          • 1704
          Front should be the 33mm. VAG2069a
          Mike
          http://www.s2-audi.co.uk
            Cool - isn't the 29mm correct for S2 - B3 and B4 ?
            I've not measured it yet.
            • Mikes2
              • 1704
              For the rear it's the 29mm
              Mike
                No not that one mark.
                • mcandmar
                  • Apr 2004
                  • 5118
                  Ooh right, i see what you are talking about now. Have you tried heating the cap with a torch?
                    Originally posted by John B
                    Hi Paul
                    JB
                    You have a PM John
                      No not yet but figured I will need the right tool to swing the booger out.
                        Oh great - so I will need two then :-(
                        • mcandmar
                          • Apr 2004
                          • 5118
                          Stilson and pipe always worked for me, but the odd few have needed heat if they had never been apart before. The hardest part is getting a solid hold of the strut, i even broke a vice clean in two hanging off one with a pipe
                            These have been on there for 23yrs - I had to check that age in my head there. Says something good about the OE dampers.
                            Maybe I will try a little thermal persuasion. Not sure my vice is up to huge abuse either - the bench isn't bolted to floor either. I digress.
                            • mcandmar
                              • Apr 2004
                              • 5118
                              I remember somebody on the forum wedged the steering arm into a metal drain in the street
