Koni STR.T - Huge disappointment
    #31
    Cool the beans alright !
    • hunker7
      • Mar 2014
      • 3487
      #32
      Dave, I honestly have no clue what you're on about?
      '93 Audi UrS4 Avant
      '15 Audi A7 quattro 3.0 TDI
      • hunker7
        • Mar 2014
        • 3487
        #33
        Originally posted by Vorsprung durch Technik
        Good old Dad!
        He's saved my *** many times
        '93 Audi UrS4 Avant
          Nobody I know/have ever met would try to show the action of a shock (strut insert) in the way you have, i.e. effectively disconnected from the top of the strut, without restraint.
          If you are complaining about the shock, didn't you try a push/pull on the shaft *BEFORE* you went to all that work to install it in the strut? That would make sense. Your "test" does not.
          That is what I'm on about.
          But all that said, let's drop it and move on. Nothing to see here (now) folks.
          • hunker7
            • Mar 2014
            • 3487
            #35
            Yes I did, and they were fine. After installing and driving I noticed nose was diving and cats were hitting the floor. I've driven the car to show how soft they are, as you can seeI'm the videos. This was the last thing I wanted to do to be 100% they're shot before spending even more money and sending them off for testing.
            '93 Audi UrS4 Avant
            • hunker7
              • Mar 2014
              • 3487
              #36
              Small update. "Initial dyno testing has found no fault with them so they are going back to the factory for engineer inspection."
              Do not know how you test shock absorbers on a dyno (unless there is shock dyno )
              What would be my options if they come back and say they're filly functional?
              '93 Audi UrS4 Avant
              • diesel des
                • 3896
                #37
                There are shock dynos. They just sound way to soft by design.
                • hunker7
                  • Mar 2014
                  • 3487
                  #38
                  I see. They're gas shocks so I shouldn't be able to push them in with one finger. Also, when I push them in, they do not come out properly, they're like catching. When I shake them I can hear knocking coming from inside the shock absorber. Oil inside them slosh around, sounds like water.
                  '93 Audi UrS4 Avant
                  • hunker7
                    • Mar 2014
                    • 3487
                    #39
                    If they are soft by design, then it is just misleading. If I purchase shock absorbers for an S4 they should be as stiff as originals. My 200k boge were as soft as new konis.
                    '93 Audi UrS4 Avant
                    • AndyP
                      • 6049
                      • igor136
                        • Jun 2014
                        • 363
                        • Country: Croatia
                        #41
                        Is it possible that the spring is stronger than the shock?
                        1-2-4-5-3
