I want to get a few suspension bits hot-dip galvanized in the next few weeks, would it be a good idea to do the stabiliser-bar as well? Or is it tempered and would it do more bad then good?
Galvanising Stabiliser?
When you say stabiliser bar?.....do you mean the anti-roll bar which is secured by 2 clamps to the subframe and has a link rod at each end connecting it with the struts?
I would say no as it is sprung steel, but I'm sure someone can give you a more technically correct answer! -
Don't galv the ARB you will take the temper out of it.Comment
