If it is a UFO hub, there would be a brake disc issue, as _ShurikeN mentioned before.
ACOQ 7a : 108 -> 112
Originally posted by _ShurikeN View PostDifferent front hubs can be applied to CV and hubcarrier, same as discussed above. But all of them have larger offset, which will cause brake disk height and wheel offset issues. UrS6 hub 441501653B is the best for that.
No simple bolt-on solution except S2 genuine hubs but UrS6 hub with some customization can be a neat solution because many of us usually do rear brake upgrade and use OEM audi wheels with big ET.
a glimpse of my Capri MK1 project
Originally posted by pfi View Postmby easier to make a shim on the 14mm strut-leg and use 12mm bolts ?
