ACOQ 7a : 108 -> 112
  • M2ki
    • Aug 2015
    • 547
    If it is a UFO hub, there would be a brake disc issue, as _ShurikeN mentioned before.
    1989 Audi 80 Quattro
    • pfi
      • Jun 2016
      • 274
      • Country: Norway
      Originally posted by _ShurikeN
      Different front hubs can be applied to CV and hubcarrier, same as discussed above. But all of them have larger offset, which will cause brake disk height and wheel offset issues. UrS6 hub 441501653B is the best for that.
      No simple bolt-on solution except S2 genuine hubs but UrS6 hub with some customization can be a neat solution because many of us usually do rear brake upgrade and use OEM audi wheels with big ET.
      I like less ET )
      a glimpse of my Capri MK1 project
      • pfi
        • Jun 2016
        • 274
        • Country: Norway
        The UFO has a bigger (pic #3 ref C) diam, mine are machined down to ~130mm,
        Is this ok or any other issues ?
        • _ShurikeN
          • Mar 2010
          • 733
          • Country: Russian Federation
          UFO brake disc has its different central hole, not like one of usual audi brake disc. So, there is a small difference in hubs.
          • pfi
            • Jun 2016
            • 274
            • Country: Norway
            #20
            ok, and what is the usual audi brake disk central hole dia ? 68 mm ?
            • M2ki
              • Aug 2015
              • 547
              Bought a pair of rear bearing housings from B4 2.6 avant and they are 75mm
              I thought all B4 2.6 and 2.8 avant quattros have 82mm bearing on rear axle.
              • pfi
                • Jun 2016
                • 274
                • Country: Norway
                #22
                Sorry, don't know anything about the avant ...
                • Steve fh
                  • Nov 2019
                  • 1
                  Hi. Are the hub carriers with 12mm and 14mm strut bots the same casting machined with different size holes or is the 14mm hub actually bigger ?
                  IE if you machine the 12mm holes out to 14mm are the hubs then identical?
                  • M2ki
                    • Aug 2015
                    • 547
                    Hubs are different. They are bigger.
                    • pfi
                      • Jun 2016
                      • 274
                      • Country: Norway
                      #25
                      AFAIK Hubs are the same ...
                      some have claimed the 12mm carriers have to thin material to drill up to 14, others say's it's ok to drill, not checked myself
                      • pfi
                        • Jun 2016
                        • 274
                        • Country: Norway
                        #26
                        mby easier to make a shim on the 14mm strut-leg and use 12mm bolts ?
                        • LHD_Kid
                          • May 2006
                          • 3696
                          #27
                          Exactly what I did...
                          • pfi
                            • Jun 2016
                            • 274
                            • Country: Norway
                            #28
                            nice
                            • _ShurikeN
                              • Mar 2010
                              • 733
                              #29
                              I would agree with that. M12 carriers I hold in my hands were too thin for reboring to M14. Maybe there are different casting versions, not sure.
                              • pfi
                                • Jun 2016
                                • 274
                                • Country: Norway
                                #30
                                At last I got a pair of 4A0501653D and after a round in a lathe it's a perfect fit
                                Got a spare set of UFO hubs if anyone interested ...
