ABY/ADU ps pump va 200 3B vs S4/S6 V8
  • Henka
    • 585
    • Home: Sweden
    So I'm looking into this whole PS-pump deal. What is the difference between the different pumps? All of them are tandem pumps, one outlet for steering and then one step for brakes. What is the difference? The p/n differs between the units:
    S2 ABY/RS2 ADU 8G0 145 165 X
    200 3B 054 145 165 B
    S4/S6 V8 054 145 165 L and D and LX
    They all look the same but what are the differences? I know that the pump in the S4/S6 V8 have a tag that says 120bar. I wonder if that is the pressure for the steering (which would be too high??) or if it the pressure in the brake cirquit (which would be too low?)??
    Anyone know this? Problem is my pump is leaking and I need to know which pumps I can use OR why I can't use some pumps. I do NOT want to fork out the dough for a new S2 ABY pump that's for sure - I'd rather buy a full set of Porsche calipers.
  • ~Delta
    • Apr 2005
    • 797
    Why not use a single chamber pump from a type 89 Audi Coupe (NG / KV)? That way you revert back to vacuum servo and stock master cylinder. I have carried out this conversion, and can tell you, the brakes certainly have more feel. Certainly no more issues with leaking pumps!
    Interesting to see Audi have dropped the whole hydraulic servo palava on current cars, high performance or not.
    Never show a fool a half built house.
    Never underestimate the power of stupid people in large groups.
    Life is like a **** sandwich
    The more bread you have, the less **** you eat
    • Henka
      • 585
      • Home: Sweden
      The thought has crtossed my mind more than once. You have a PM...
      • WabTheKing
        • May 2004
        • 2567
        tell me more
        • Henka
          • 585
          • Home: Sweden
          Thread
          Well I started a thread about converting from hydro to vacuum a while ago:
          Please click here.
            From memory the S2 power steering runs at approx 140bar - hydraulic systems run at scarey pressures. I know of a guy who almost had his arm severed off by a thin jet of hydraulic oil that squirted out of a burst hydraulic line on a JCB digger.
            • WabTheKing
              • May 2004
              • 2567
              heard a simalar horra story about a high pressure grease gun
              makes you shiver!
              • Henka
                • 585
                • Home: Sweden
                Anyway, the pump in my S2, the stock unit 'H', is rated at 100bar FYI.
