Got that sorted out on my S6, boy what a difference gone is the heavy moaning (release bearing totally shot) to be replaced with a light joy to use clutch that's even improved the gearchange too. Only minor concern is that when i back out of the drive (it's pretty steep) i get a whiff of burning clutch i suppose this bedding in just like brakes???
Iain
Makes a world of difference doesn't it. Fit a short shift kit to further improve the change of the S6.
I assume you also bled the slave cylinder?
Oh yes slave cylinder took 3 goes to bleed, it was full of old green fluid of some description or other. Short shift kit sounds like a nice idea where from???
Iain how much did the clutch cost or did you do it your self ,how many miles ,mine is on 190000 so it wont be long ,far as I know its the original cluth come to think of it original exhaust and turbo and radiator and rack and fuel pump and ,and ,and , and it looks like im in for a dear old time soon .
9 hours @ £35 an hour if you have me do it.
Clutch from me (genuine Sach's item, unless you want an uprated item) £178.65
replace the rear oil seal while in there £20
new clutch slave cylinder £45
and the guide that the release bearing slides on £30.46
these are as a minimum, if you do it by removing the engine then there are other parts to replace while in there.
Clutch kit cost me £98.00 exchamge plus the guide sleeave but then i do work where i can buy parts cheap, got a friend to fit it who works in an audi dealer as a private job, charged me £180.00 but that also includes fitting suspension bushes various and a 4 wheel alignment.
